Offset faces in one go
 1-12  13-31
So I think Inset can do it currently, try setting the Thickness = 0 so it won't make a border and then check "use separate height" and put in your offset distance as the Height value.
If you want to keep the cut away portion as a separate object you can do that by checking "Grooved" and set groove width to 0.
10376.14 In reply to 10376.13
Missed that sneaky frontal assault from the rear!
That does it.
10376.15 In reply to 10376.13
Michael,
Is there any "robustness" left in the geometry kernel regarding Offset\Shelling that you just haven't implemented? Or are we at the limits of what's available...
10376.16 In reply to 10376.1
Hi Paquicinno, also one thing to note is that with surfaces that are not at a 90 degree angle to each other, offsetting surfaces will be a different result than offsetting edges + loft like you were doing before.
Inset don't work for this objects! ... ;)
EDITED: 24 Jun 2021 by PILOU
10376.18 In reply to 10376.15
Hi Burr,
Not really - it's got some fundamentally broken assumptions in it in this area. I think it could be a possibility to write a new one from scratch (unlike fillets) but it might be better to try to get this area better by integrating a different geometry kernel which I have to do anyway to improve fillets.
10376.19 In reply to 10376.17
It's working for me over here. Set Thickness = 0 and check "Use separate height" and put in the offset distance as the height value.
re: video - in your video you're not following the instructions I posted above.
10376.20 In reply to 10376.17
Frenchy,
10376.21 In reply to 10376.18
Michael,
Aha! Well, fingers crossed for what the future holds on that...
10376.22 In reply to 10376.20
Aaaah! Damned! It's a secret trick! :)
Excellent! Absolutly not logic but if it's works... :)
The Inset Function is endless surprising!
10376.23 In reply to 10376.22
Basically the Inset command is focused on carving off a slab of the object and doing some other work on it but in this case you want to just throw away the slab and not have a border around it.
10376.24 In reply to 10376.23
I don't think the inset command gets the love it should. For me, the nomenclature just didn't "speak" to me, or "make perfect sense...
So, for me, it may be adding a second tick.
To me, "inset" would be "how deep the slab carved off. (No border preserved)
Then a tick for border thickness adds the outer border, at some thickness.
Then groove, changes the slab removal, into a groove removal.
Then "use separate height" would add a second depth to the "slab part", separate from the groove part...
I think i really just need to spend an hour on the inset command, to wrap my head around it and its setup better....
10376.25 In reply to 10376.24
So i just revisited the inset command with regards to what i just said.
So the initial inset and value, just combines both the depth and border as a single value.
Then use separate height adds the separation between the 2.
The grove value uses to 2 separated just like the first choice, but loses the initial "slab depth" value, and ability to separate that out... the grove is controlled by the separate height and groove values. The initial thickness value is missing
And what a complexity when it's applyed to just adjacent faces! Internal / external! :)
10376.27 In reply to 10376.26
Hi Michael, the inset trick works perfectly, just simple and easy. Thank you all.
10376.28 In reply to 10376.27
And what's great is the opposite result with a negative value in the height field. An easy way to extrude some tricky faces of a solid.
10376.29 In reply to 10376.28
""""""""" the opposite result with a negative value in the height field"""""""""""
There is also an inwards/outwards toggle in the command.
And when you choose outwards, a different field activates called "Expand".....
10376.30 In reply to 10376.29
Made a quick doodle with Offset.... Just dropping this here...
@ Burr Cool Subdiv modeling! ;)
For the French Tips & Tricks! ;)
https://moiscript.weebly.com/trucs-astuces.html somewhere on the page dedicaced! :)
Show messages:  1-12  13-31
