Offset faces in one go
 1-20  21-31
10376.1
Hi, is there some easy way to way to offset in one click all the 4 faces in red by a number ? Here all the faces are reduce of 15 mm. I need that to easily put some adjustment for doors, for example. I can do that the hard way, of course, but if i have a lot of objects, (not always doors, and not always rectangles ) , it is quit time consuming.
Thank you.
Paquicinno
Size: 17.9 KB, Downloaded: 84 times, Dimensions: 657x318px
10376.2 In reply to 10376.1
For the moment maybe only Elephant can do that...
EDITED: 24 Jun 2021 by PILOU
10376.3 In reply to 10376.1
By "offsetting faces" you mean bringing all the edges toward the center of the face?
Max has a script for this.
Or maybe you are referring to the inset command.
10376.4 In reply to 10376.3
Hi BurrMan, when i do it the hard way, i offset the front and the rear faces edges by some value, then loft the two sets of curves. Is that clear ?
10376.5 In reply to 10376.4
Ok, it's like extrude each 4 red faces to the center by some value, as if i could make some place for siding. In this case, the siding is 15 mm thickness.
10376.6 In reply to 10376.5
Here is a better way to illustrate what i need.
Maybe like this ;)
But you must select (or extract) the 2 Lateral Sides edges for input them inside the Selected Nodes!
So 4 Clicks ( 2 for selection, 2 for input nodes) and read some little things about the Elephant nodes System by Max Smirnov... :)
that can't maybe not a pleasure party! :)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/offset_lofts.nod
10376.8 In reply to 10376.6
Hi jfs,
Havnt looked at the 3dm's yet as i'm on my phone, but from the description, you are looking for "inset" command.
But maybe you know this command and it's not working in this case?
I'll have to get a look at the file if nobody else chimes in soon.
10376.9 In reply to 10376.1
Hi Paquicinno, probably that's what offset of a face selection ought to do but it isn't what it does currently. Currently for a face selection it separates out the selected faces same as using Edit > Separate and then offsets that separated piece.
Are the objects you want to process like this a cuboid type shape bounded by planar faces on all sides? If so I can probably cook up a script to do this.
After seen your third file it's -15 that you must enter inside the Constant Node ! :)
So what will be the more simple : select 2 loop of edges by my system
or the 4 faces of the futur soon Michael ?
The Michael one will surely more polyvalent! :)
And avoid some headaches! :)
And no need to have 2 Selected nodes! :)
Alas seems the Offset "internal" bugged! :(
10376.11 In reply to 10376.8
So, just looked at the last file.
10376.12 In reply to 10376.9
""""""""""Are the objects you want to process like this a cuboid type shape bounded by planar faces on all sides?"""""""""""
No, kindof twisted a bit...
So I think Inset can do it currently, try setting the Thickness = 0 so it won't make a border and then check "use separate height" and put in your offset distance as the Height value.
If you want to keep the cut away portion as a separate object you can do that by checking "Grooved" and set groove width to 0.
10376.14 In reply to 10376.13
Missed that sneaky frontal assault from the rear!
That does it.
10376.15 In reply to 10376.13
Michael,
Is there any "robustness" left in the geometry kernel regarding Offset\Shelling that you just haven't implemented? Or are we at the limits of what's available...
Thanks.
10376.16 In reply to 10376.1
Hi Paquicinno, also one thing to note is that with surfaces that are not at a 90 degree angle to each other, offsetting surfaces will be a different result than offsetting edges + loft like you were doing before.
Inset don't work for this objects! ... ;)
10376.18 In reply to 10376.15
Hi Burr,
Not really - it's got some fundamentally broken assumptions in it in this area. I think it could be a possibility to write a new one from scratch (unlike fillets) but it might be better to try to get this area better by integrating a different geometry kernel which I have to do anyway to improve fillets.
10376.19 In reply to 10376.17
It's working for me over here. Set Thickness = 0 and check "Use separate height" and put in the offset distance as the height value.
re: video - in your video you're not following the instructions I posted above.
10376.20 In reply to 10376.17
Frenchy,
Show messages:  1-20  21-31
