How would you model this? Locomotive louvers
All  1  2-6
10374.2 In reply to 10374.1
Draw three curves. The Red & Blue are at 90 degrees to each other. Their end points must touch.
Select all three curves and Network.
Select the surface and Shell if you need a Solid.
From there you can Array to make copies and then Boolean Union with your model.
10374.3 In reply to 10374.1
Using solid dies...
10374.4 In reply to 10374.3
After looking at your reference again, I made another where I pre cut the vent die to be horizontal before the process. Then I did the cutup a different way too.
10374.5
Thank you all for your help!
Chris
Show messages: All  1  2-6
