Hi pior, the other way you can do it is to press the Tab key which will put focus in that field and select all text without needing to use the mouse to do it. You can use this method if you have a bunch of shortcut keys set up.
Just type your text before the default one then Press the Delete keys at the end of the new text until the default text will be erased...
Not a big deal! :)
Hello FP,
Sure enough that's another way to work around the issue, but any UX issue is worth reporting IMHO, as I believe it can only make the software better in the long run.
