Moi v4 freezing/crash.
 1-16  17-28
10363.17 In reply to 10363.15
Hi 2byts, I was looking over the crash dump info a little more and I noticed another possible hooking thing: NahimicOSD.dll .
It seems to be part of your audio driver which has several DLLs loaded but the "OSD" part of that one probably means on-screen display so it's another possible source of interference and has also caused crashes in other apps previously too:
https://support.microsoft.com/en-us/topic/office-applications-crash-due-to-nahimic-audio-driver-1a7cdd29-5c89-4579-9043-faa97120ff92
https://github.com/visualboyadvance-m/visualboyadvance-m/issues/623
If you can figure out a way to turn off that piece as well that might be worth a try.
It's a little strange that the audio driver has something that hooks into the video driver display code but that is what it appears to do.
10363.18 In reply to 10363.15
It looks like you might be able to find a Nahimic service running which you could disable in Win+R services.msc .
10363.19 In reply to 10363.17
Kind of sounds pretty close to what you are describing:
https://answers.microsoft.com/en-us/windows/forum/windows_10-other_settings/nahimic-audio-issues/7c10e6ec-01bb-49ea-ba21-a93e037dca81
quote:
I had the same ploblem with sound , but I got other problems with 3D apps that are not games. Unable to open stl or ply files, refreshing of windows piling on the top of each other, a nightmare before finding the problem. So I just stopped/deactivate NahimicService, and the result is instant. You restart your programs and all goes well. Win10 2004, last version of Nahimic on 2020-04-26
So definitely worth a try disabling that.
10363.20 In reply to 10363.15
10363.21 In reply to 10363.20
It is an Asus ROG Zenith II Extreme Alpha motherboard.
10363.22
Thankyou Michael!
I will look into the Nahimic driver during the week when I am modeling.
Motherboard is Asus ROG.
v3 is so stable, I dont know how to crash the software actually! I think the only time I have made it crash was from out of memory during polygon exports. It is literally the most stable 3d application I have ever worked with it.
10363.23 In reply to 10363.21
Hi 2byts, so yeah I guess it is both ASUS as well as MSI that use this Nahimic sound driver that has some kind of display driver hook apparently.
Another comment here about it interfering with Houdini:
https://www.reddit.com/r/ASUS/comments/asot4q/nahimic_service_causing_problems_all_around/
10363.24 In reply to 10363.23
EDITED: 19 Jun 2021 by 2BYTS
10363.25 In reply to 10363.24
Hi 2byts, hopefully that's the answer but we'll see... Bad drivers can always be a problem but this is the first time I've heard of a sound driver that's so bad it messes up the video driver as well.
If that does solve it, you can reset the moi.ini settings back to their defaults which are:
DisplayThreadLimit=
StaticBufferMaxVRAMToUseMB=
those being just blank, and then
GraphicsAPI=Auto
Hope that will work!
10363.26
Disabling Nahimic in services, seems to solve the issue completely. No crashes at all. Thankyou for your assistance Michael.
10363.27 In reply to 10363.26
Hi 2byts, you're welcome! That's great I'm glad you have a solution.
Who would have guessed that it would be the sound driver? The worst sound driver in history it seems...
10363.28 In reply to 10363.27
""""""The worst sound driver in history it seems..."""""
I actually rolled on the floor!!!
Show messages:  1-16  17-28
