Generating an airfoil wing from a cross-sectional profile at the base and rails defined by the wing's intended leading and trailing edges
All  1  2-4
10361.2 In reply to 10361.1
Hello LarryV,
try to improve your curves, as they have a lot of segments. You need as smooth curve as possible. In this simple design there are sharp leading & trailing edges of your wing, so simple mirroring of upper surface and lower surface can be used. I have used only curves from your model. Sweep command with tangency work quite easily.
Hi Larry,
I hope I've understood what shape you're going for.
I created this solid using a 2 rail sweep. The rails are the green and blue curves (I re-drew them using continuous Freeform curves). The 2 profiles are the red closed curves.
Select the 2 red curves, run Sweep, and select the green & blue as the rails.
Adjust the red oval as needed to get the desired thickness near the wing tip. You can also add more red profile curves if needed to fine tune the taper of the wing.
If you want precise control over the wing taper you can add a Scaling Rail (light blue curve in 3rd image). Same sweep operation as above except first delete the small red profile curve. Sweep as above and click "Pick scaling rail", then Done. History is on, so you can show points on the scaling rail and tweak the taper in real time.
You can also select the same set of curves all at once and Network (last image). Again, select the the light blue "Scaling Rail", turn on "Show Points" and tweak the wing taper . The Network method does not produce a Solid, so after Network, select the large red closed curve and Planar. Then select all the surfaces and Join to make the wing Solid.
If you want more radius on the wing edges then modify the airfoil closed curve ends to be less sharp.
Try all methods.
EDITED: 14 Jun 2021 by EDDYF
10361.4
Thank you both for your input! These are both excellent solutions. I didn't realize that the rails need to be continuous, which they weren't in my model. I was selecting multiple consecutive, disjointed segments and that's why it wasn't working.
I now tried copying the edges of the reference ground plane projection of the wing, deleting that surface, joining the different segments of the leading and trailing edge profile into two individual singular continuous curves and then I was able to use sweep to make the wing shape I wanted.
Thanks a lot, you've helped me out tremendously!
Best regards,
Larry.
Show messages: All  1  2-4
