Zoom all quad views in or out at once
All  1-6  7-11
10352.7 In reply to 10352.6
HI Carlos,
> Is this possible in Options (zoom independent and together) and also a short-cut?
There is an option under Options > View > Rotate/Pan/Zoom options > "Link ortho views" which will keep the Top/Front/Right views to be all at the same zoom level. When that is enabled if you zoom in the Top view for example, the Front and Right views will also update.
Is that what you were asking about or is it something different?
10352.8 In reply to 10352.7
Wow, that's a useful hidden option I hadn't discovered yet, thanks Michael!
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
10352.9
Yes, but be able to turn it off/on with a short-cut?
10352.10 In reply to 10352.9
Hi Carlos, you can set up a shortcut key to toggle the "Link ortho views" option on or off with this:
script: /* Toggle link ortho views */ moi.view.linkOrthoViews = !moi.view.linkOrthoViews;
10352.11
Thank you Michael.
Show messages: All  1-6  7-11
