Zoom all quad views in or out at once
All  1  2-11
10352.2 In reply to 10352.1
Hi Metin,
> I was wondering if it would be possible to zoom all viewports in or out at the
> same time, with one zoom gesture?
Try setting up a shortcut key with this script on it:
script: /* Zoom all viewports out a little */ var vnames = [ 'Top', 'Front', 'Right', '3D' ]; for ( var i = 0; i < 4; ++i ) { moi.ui.mainWindow.viewpanel.getViewport(vnames[i]).zoom( 1.1 ); }
10352.3 In reply to 10352.2
Great, thanks for your service Michael!
Enjoy your weekend!
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
10352.4 In reply to 10352.2
and anything below 1 in zoom( x ) field will zoom in! The closer to 1, the smaller the zoom increments. (for example zoom( 0.9 ) )
I have no clue about scripting, but I just tampered with it like a monkey in a spaceship lol
10352.5 In reply to 10352.4
Haha, nice to know, thanks!
─ Metin
10352.6
Hello Michael,
Is this possible in Options (zoom independent and together) and also a short-cut?
Thank you.
10352.7 In reply to 10352.6
HI Carlos,
There is an option under Options > View > Rotate/Pan/Zoom options > "Link ortho views" which will keep the Top/Front/Right views to be all at the same zoom level. When that is enabled if you zoom in the Top view for example, the Front and Right views will also update.
Is that what you were asking about or is it something different?
10352.8 In reply to 10352.7
Wow, that's a useful hidden option I hadn't discovered yet, thanks Michael!
─ Metin
10352.9
Yes, but be able to turn it off/on with a short-cut?
Thanks.
10352.10 In reply to 10352.9
Hi Carlos, you can set up a shortcut key to toggle the "Link ortho views" option on or off with this:
script: /* Toggle link ortho views */ moi.view.linkOrthoViews = !moi.view.linkOrthoViews;
10352.11
Thank you Michael.
Show messages: All  1  2-11
