Insert Circle script
 1-8  9-25
10340.9 In reply to 10340.8
i suppose this one! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=9266.93
The dog's bone! :)
EDITED: 28 May 2021 by PILOU
10340.10 In reply to 10340.9
Aha!!!! 2019....
I was possibly in a Morphine haze At the time....
Thanks FP.
EDITED: 28 May 2021 by BURRMAN
10340.11 In reply to 10340.2
Can you modify InverseFillet to allow for picking the spots, like the InsertCircle script?
It is currently a global selection.
That would be banner!
10340.12 In reply to 10340.11
Hi Burr, do you mean selecting points for which corners to apply it onto like regular fillet?
10340.13 In reply to 10340.2
Thanks Michael, thats brilliant. BurrMan's suggestion of being able to select the points to fillet would be awesome as some points need to be treated separately.
Colin
10340.14 In reply to 10340.12
"""""""""""""""" do you mean selecting points for which corners to apply it onto like regular fillet?""""""""""""""""
Well, that would work, but the other script just has access to the various pick points and just inserts as you click.
10340.15 In reply to 10340.14
Hi Burr,
Wouldn't that be the same thing as InsertCircle then?
10340.16 In reply to 10340.15
Well, with the inversion added. Insert circle only goes 1 way...
Let me check
10340.17 In reply to 10340.16
Yup, just checked.
So insert circle has the actual picking ability, but it only does it additively. It would need the inverse added to it.
or
Inverse fillet does have the flip option, for adding or subtracting. But it doesn't have the ability to pick where this happens. It just globally applies it to closed curve "corner points".
The pick point method doesn't even need a corner point. You can place it "Anywhere".
So I guess the optimal would be the InsertCircle command with the flip option added in...
10340.18 In reply to 10340.13
Hi Colin, I've updated the inverse fillet in the attachment above so you can select which vertices to target.
10340.19 In reply to 10340.17
Hi Burr, I've updated the InsertCircle script to have a "Flip" option now:
Cool additions!
10340.21 In reply to 10340.19
That's it!!!
Thanks Michael. Really appreciate it.
10340.22 In reply to 10340.20
Very usefull script
Mik
10340.23 In reply to 10340.18
Thats really cool, thank you so much. I normally start my designs in Moi and then transfer to Vectric V-carve to add dogbone fillets, but this script means all I'm using V-carve for is the CNC path generation.
Colin
Insertcircle
Funny form with only a revolve on it's perpendicular profil :)
Always fun! :)
My Moi French Site
Show messages:  1-8  9-25
