Insert Circle script
 1-20  21-25
10340.1
Have just discovered this script and wondered if it can be modified to work on the inside of closed curves ( see my attached example) rather than the outside. Ideally I would want to preselect my point set rather than select individual points. I often use this to create cutting paths for my CNC machine.
Colin
Size: 53.9 KB, Downloaded: 121 times, Dimensions: 1120x1144px
10340.2 In reply to 10340.1
Hi Colin, is this one close to what you're looking for?
EDIT: 5/29/2021 - updated attachment, added selecting vertices to target.
EDITED: 29 May 2021 by MICHAEL GIBSON
10340.3 In reply to 10340.2
Inverse fillet script (normal & flipped) applied to a polygon and swept.
Always good to have one more tool in the MoI toolbox :)
Does it possible to have an Inverse Fillet for volume ?
10340.5 In reply to 10340.4
Unfortunately no that's much more difficult.
InverseFillet above is not the "Dog's bone" curve ?
Very cool form on repeating the function!
Seems curves must be coplanar ?
EDITED: 28 May 2021 by PILOU
10340.8 In reply to 10340.1
""""""""""""Have just discovered this Insert Circle script""""""""""""""""
What script is that please?
Thanks.
10340.9 In reply to 10340.8
i suppose this one! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=9266.93
The dog's bone! :)
10340.10 In reply to 10340.9
Aha!!!! 2019....
I was possibly in a Morphine haze At the time....
Thanks FP.
EDITED: 28 May 2021 by BURRMAN
10340.11 In reply to 10340.2
Can you modify InverseFillet to allow for picking the spots, like the InsertCircle script?
It is currently a global selection.
That would be banner!
10340.12 In reply to 10340.11
Hi Burr, do you mean selecting points for which corners to apply it onto like regular fillet?
10340.13 In reply to 10340.2
Thanks Michael, thats brilliant. BurrMan's suggestion of being able to select the points to fillet would be awesome as some points need to be treated separately.
Colin
10340.14 In reply to 10340.12
"""""""""""""""" do you mean selecting points for which corners to apply it onto like regular fillet?""""""""""""""""
Well, that would work, but the other script just has access to the various pick points and just inserts as you click.
10340.15 In reply to 10340.14
Hi Burr,
Wouldn't that be the same thing as InsertCircle then?
10340.16 In reply to 10340.15
Well, with the inversion added. Insert circle only goes 1 way...
Let me check
10340.17 In reply to 10340.16
Yup, just checked.
So insert circle has the actual picking ability, but it only does it additively. It would need the inverse added to it.
or
Inverse fillet does have the flip option, for adding or subtracting. But it doesn't have the ability to pick where this happens. It just globally applies it to closed curve "corner points".
The pick point method doesn't even need a corner point. You can place it "Anywhere".
So I guess the optimal would be the InsertCircle command with the flip option added in...
10340.18 In reply to 10340.13
Hi Colin, I've updated the inverse fillet in the attachment above so you can select which vertices to target.
10340.19 In reply to 10340.17
Hi Burr, I've updated the InsertCircle script to have a "Flip" option now:
Cool additions!
Show messages:  1-20  21-25
