Blend problem
10338.1
Hello,
I have some problem with Blend between open edges.
I'm using V4 and there is no problem when I used V3 and V4 beta.
What's the problem?
Thanks.
10338.2 In reply to 10338.1
Hi sandykoufax, can you please post the .3dm model file?
Thanks, - Michael
10338.3 In reply to 10338.2
Hello,
I attached 3dm file.
10338.4 In reply to 10338.3
Hi sandykoufax, I think you're running into just a display glitch where you're getting a rough display mesh.
Try going to Options > View > "Meshing parameters" and set the checkbox for "Add detail to inflections" to be on. Does it clear that up?
Also even without doing that if you do a mesh export it should look ok there, it's just a problem with the display mesher.
10338.5 In reply to 10338.4
It works!
I checked "Add detail to inflections" option and problem has solved!
Thank you!
JH.
10338.6
ohayo
as we are on same object wanna ask about optimization - as far 3 faces must be updated
I've noticed as object becomes more complex, more surfaces attached, the slower calculations are
from file attached ~1 sec to attached object vs detached ~ almost instant
- Tudor -
Size: 303 KB, Downloaded: 53 times, Dimensions: 1209x1195px
10338.7 In reply to 10338.6
Hi Tudor,
Yes, that's normal. When you have more data in your object it will take longer to send it over to the moi_commandprocessor.exe for it to be processed over there and then sent back.
