Flow & Vase mode
All  1-8  9-11
My theory is that your problem comes from your "Vase mode".
Your object is a full solid and plain vase.
Your software wants to do the same thing as a "Shell" operation.
Without the patterns, it's OK, I think. but with it, this mode could give you some problems.
My advice is to do a real vase with your revolution surface (unselect the cap ends checkbox), and do a Shell on it (or do a surface of revolution with a closed curve with inside and outside.
Next you add the patterns.
A theory to be verified...
10336.10
I don't see a problem in Cura. Your pattern sticks out too far creating overhangs though, which will result in holes on vertical surfaces.
10336.11
Thanks everyone for your help. Phiro, re Vase mode: I've created some complex surface patterns using other methods, and although these have made the object difficult to shell, vase mode in S3D has handled it well. I'll use all these thoughts to make something more interesting, and see how I go :)
Show messages: All  1-8  9-11
