Fillet after Union
All  1-8  9-11
10329.9 In reply to 10329.8
Thank you for your reply. I have more question I'm afraid. Please bear with me.
I managed to untrim the curved surface (c) and I copied out the profile curves (d) + (e).
I aligned them and joined them using join, (tried exporting using SAT but I’m not understanding what step) and then I extruded it (f).
Could you explain the step involving the SAT in detail please?
I’m guessing i need to make a curved surface like in (f) but without the corner point creating a line in the middle (x)?
Next I would need to trim it with (b) ?
If the points of the curve profile (y) are out of alignment in (b),wouldn’t that make union with the trimmed surface impossible?
10329.10 In reply to 10329.9
Hi dodeqaa,
That's the part that's pretty tricky - a side effect of exporting a joined curve out to SAT format is that in the SAT file it will be curve made up of just one segment, multiple segments will be fused together. When you then import it back in, it will get broken into separate segments at any tangent discontinuities but areas that are tangent will remain as a long segment.
When you do an extrude you'll get a separate face for each segment in the input curve, so to eliminate edges between faces you want to get this curve to be composed of just one segment instead of multiple segments which is what you get currently with the Join command.
Yes, I trimmed it with the naked edges of the main object.
> If the points of the curve profile (y) are out of alignment in (b), wouldn’t that make union with the trimmed surface impossible?
If it's a small enough change then it can still get joined. If it's too large of a shift then yes some other reconstruction steps would be needed.
10329.11
Hello Michael,
Thank you for the explanation and your patience. Works like a charm!
Made the mistake of moving the tangent points to line up with the curve point above, that left a gap in the geo.
Changed it up and move the curve point above the tangent points (I guess that's what you meant by first interior point).
Show messages: All  1-8  9-11
