Fillet after Union
All  1-3  4-11
10329.4 In reply to 10329.3
Hello Michael,
Thanks! That works great!
May I know how you reconstructed the curved surface please?
10329.5 In reply to 10329.4
Hi dodeqaa,
Well it's kind of tricky.. First used Edit > Separate on the 2 surfaces to break them out from the main object. Then selected the edges of the curved one and used Delete to untrim them and recover the full underlying surface. That then allows to select the side edge curve of it and use Ctrl+C/Ctrl+V to duplicate it as a curve and then delete the surface. Then positioned the lines from the bottom planar surface next to that side curve and edited control points to move the first interior point of the curved one so that it was aligned with the line's direction so they were smooth to each other. Then to fuse them together i used a trick where exporting a joined curve to SAT format and reimporting it will fuse tangent pieces together into longer curves. Then extruded that and trimmed it and joined it back in.
10329.6 In reply to 10329.4
That whole process for combining faces is definitely something that I want to make easier to do.
10329.7 In reply to 10329.6
Thank you for the detailed reply! I'm stumped on the steps, I managed to separated the 2 piece sin question but selecting the edges of the green curved surface and pressing delete doesn't do anything?
10329.8 In reply to 10329.7
Hi dodeqaa,
You need to separate them out into individual surfaces, so for this case you need to run Separate twice. The first one will separate the 2 selected faces out from the main object but keep those 2 faces still connected to each other. Then run Separate another time to break apart those 2 surfaces into individual surfaces not connected to anything else.
10329.9 In reply to 10329.8
Thank you for your reply. I have more question I'm afraid. Please bear with me.
I managed to untrim the curved surface (c) and I copied out the profile curves (d) + (e).
I aligned them and joined them using join, (tried exporting using SAT but I’m not understanding what step) and then I extruded it (f).
Could you explain the step involving the SAT in detail please?
I’m guessing i need to make a curved surface like in (f) but without the corner point creating a line in the middle (x)?
Next I would need to trim it with (b) ?
If the points of the curve profile (y) are out of alignment in (b),wouldn’t that make union with the trimmed surface impossible?
10329.10 In reply to 10329.9
Hi dodeqaa,
That's the part that's pretty tricky - a side effect of exporting a joined curve out to SAT format is that in the SAT file it will be curve made up of just one segment, multiple segments will be fused together. When you then import it back in, it will get broken into separate segments at any tangent discontinuities but areas that are tangent will remain as a long segment.
When you do an extrude you'll get a separate face for each segment in the input curve, so to eliminate edges between faces you want to get this curve to be composed of just one segment instead of multiple segments which is what you get currently with the Join command.
Yes, I trimmed it with the naked edges of the main object.
> If the points of the curve profile (y) are out of alignment in (b), wouldn’t that make union with the trimmed surface impossible?
If it's a small enough change then it can still get joined. If it's too large of a shift then yes some other reconstruction steps would be needed.
10329.11
Hello Michael,
Thank you for the explanation and your patience. Works like a charm!
Made the mistake of moving the tangent points to line up with the curve point above, that left a gap in the geo.
Changed it up and move the curve point above the tangent points (I guess that's what you meant by first interior point).
Show messages: All  1-3  4-11
