What Next? Closed
 1-10  11-23
10323.11 In reply to 10323.7
Hi Andy,
> What does it matter why I wanted to explore the possibilities of MoI?
Because you're complaining about it. It's helpful for me to know if you're complaining about something if there is an actual reason for or not.
I can understand that it may be fun to explore every possible use of MoI but I'm more focused on doing things that help someone's actual work they are trying to do, not so much on just endless exploration.
> Well first of all looking at Chipp's tutorials it is impossible to follow along what he is doing without it.
Ok, then what I'd recommend is not looking at Chipp's tutorials while you are still a beginner. Those are something you can dig into at a later time when you've already gained proficiency in using the main areas that MoI is currently focused on.
> I wanted to see what it could give me and how it could improve my experience.
The problem is you are prematurely trying to improve your experience before you've actually gained experience in the regular primary targeted use of MoI.
In the future I do want to improve the process of discovering and installing add-ons. I'd like to make something like a "scripts browser" that would let you browse through a centralized depository and install by some button or checkbox control or something like that.
It will take quite a bit of work to do that so I'm not sure when it will happen. Currently it is not a top priority.
  More Options
10323.12
It's like going to the hardware store. When you go in do you go straight to what you need and leave? Or do you browse around to see what they have so that in the future when there is a problem to solve you know a solution exists at the hardware store?
You currently do not have the shelving to display things on in a way that people can browse and make sense of it and know what is available.
But also you don't have a cash register. You have one of those old clunky carbon copy credit card machines that are fiddly and take time to obtain the item you want.
Your amazing community here has taken the time to create lots of great add ons. You just now need to create the shelving to display them and make the most of their work.
As I said in my first post, this is a marketing issue. New features are nice but without marketing leading to sales there is no budget for new features.
Andy
  More Options
10323.13 In reply to 10323.12
Hi Andy, well yes actually I find marketing distasteful and have tried to get away with as little as possible. It is unusual but it has worked out fine for me. If you have a good enough and different enough and useful enough product that stays around for long enough you can get enough word of mouth to do marketing.
I will probably be doing a little effort towards regular marketing at some point here though.
Well the case here is more like you're going into a super gigantic hardware store that has a lot of items on the shelves that were custom built to solve just one person's specific problem or workflow use case.
If it takes a long time to browse through those things and you don't want to spend that time then the solution is just "don't do it".
Like I said I do want to make a plug-in browsing system which would do what you want here. LIke many things it will take time to work on it and I haven't been able to get to it as of yet.
  More Options
10323.14
The steps I outlined in my first post covered about 10 add ons. Is that considered "super gigantic"? That's all that I have installed.
In my first post I wrote "the most popular add ons". Doesn't things like rotation patterns, Custom UI, lighting, nodeeditor, etc. have wide appeal? I'm not sure why you mention about adds ons with specialized one-time use.
My *entire* point is highlighting and focusing on the most useful items, making them easy to find and easy to install.
Andy
EDITED: 17 May 2021 by ANDYA
  More Options
10323.15 In reply to 10323.14
Hi Andy,
Nope.
I am in agreement with you that it would be desirable to improve this function in MoI and I do want to do so in the future.
  More Options
10323.16
Good day.
The first thing I did when I bought Moi3d is to buy a Moi3d course on gumroad > https://gumroad.com/l/vavRq
Well worth it.
I started to customize the ui as well but I was wasting too much time on it so now my ui is mostly original and use very few scripts.
  More Options
10323.17
when I bought moi I watched these three videos https://moi3d.com/3.0/docs/tutorials.htm and read the help files. It took around a week to get up and running. I think one of the first things I made was a bathtub. A week is no time at all to learn enough to get going in 3D software. As I got more comfortable with Moi I began adding scripts and doing more with it.
  More Options
10323.18 In reply to 10323.14
Hi Andy,
""""""Hours of effort spent just so I can make my copy of MoI look like tutorials I am trying to follow on YouTube."""""
So trying to make your UI look like Chipps, from 6 years ago?
This is your error. Even Chipp's UI has changed since then!!!
The forum is your answer. If you need something. Just ask. Someone here will help you out.
Customizing the UI??? That's a personal endeavor. Endeavor to persevere!
  More Options
10323.19 In reply to 10323.14
Hi Andy,
Also, the information is mostly there on the resources page.
Like all of Max's work. And it's not "cryptic or undocumented" they have a little link to the forum post with its description, install and use instructions, etc... it's a little grey button that says "forum thread"....
But the fact that it leads you to a 467 post thread is not "bad". Thats where you read about its installation and use and issues and triumphs others have had, and other customizations made along the way.
"FULL DOCUMENTATION" that you are requesting.
  More Options
10323.20 In reply to 10323.18
The CustomUI gives access to all of the built in functionality of MoI via it's menu system. I prefer point and click to memorizing lots of keyboard shortcuts or memorizing what I can enter after pressing tab. It's just the way I like to work. What is the problem with me wanting to do that? Why all of the resistance?
I don't really consider it "customizing", but more unlocking what is there and make it easier for me to use.
Who has time to read 400 pages of forum posts? Sorry, I don't. I would prefer a "follow steps X, and Y to get Z". If getting Z requires lots of research then it's too complicated IMO.
Andy
  More Options
10323.21 In reply to 10323.19
I mentioned several times in this thread why in my opinion that approach has issues.
Nowhere in this thread did I ask for "full documentation" or anything remotely like that.
Andy
  More Options
10323.22 In reply to 10323.20
Hi Andy,
There is no problem with you wanting to do that. I have explained now several times that I would like to make it easier to browse and install plugin scripts in the future but it has not been a priority and so it isn't part of the current product.
  More Options
Thread locked since it's not going anywhere productive.
  More Options
Show messages:  1-10  11-23
