Boolean Union
All  1-2  3-5
10320.3
OK, thanks that is good to know. Andy
10320.4 In reply to 10320.1
Hi Andy,
Is that what you want?
Edit: Test3_Modified seems better.
I think you needed to sink your letters more inside of your cup so I made your cup slightly larger (0.1 larger in radius)
I also noticed your "i" is problematic! So I thickened your "i".
Select front & back faces of your "i" > Ctrl+C > Delete your "i" > Ctrl+V > Draw a line from center of your "i" toward center of your cup from top view > Move back faces of your "i" a little bit over previously made line toward Cup's center> Select edges of "i" faces (outer and inner) > Ctrl+C > Ctrl+V > Join them > use loft > Join all your "i" surfaces > you will have solid "i" (well there would be two solids) > Select all your solids > perform Boolean Union
EDITED: 15 May 2021 by DRILLBIT
10320.5
Many thanks! Andy
Show messages: All  1-2  3-5
