Shelling
All  1-6  7-8
10319.7
Thanks Ed - good suggestions. Andy
10319.8 In reply to 10319.5
Hi Andy,
> OK, so your reasoning is that because it is complicated it won't happen in MoI?
No it's simply an explanation for why it has not happened _yet_ in MoI.
> Alibre Design has no problem with it - see screenshot. <...>
Yes Alibre Design uses a geometry library called ACIS which has had something like 50 more man-years of effort put in to developing the shell and fillet geometry processing than the library that MoI uses.
I would recommend using Alibre to do your shelling instead of MoI, that way you won't have to worry about the ordering.
Shelling in MoI is pretty primtiive. When I started MoI I had hoped that the shell and fillet functions in the geometry library that I used would improve over time but the authors of the library have gone in a different direction than that.
I would like to license a different library to better handle those areas. That requires a lot of work as well though even just to investigate it.
> it becomes more important IMO for the application to do what the user expects
I totally agree! Unfortunately it will require a lot of work to make this area behave like the user expects. I have not managed to scrounge up an extra 50 years of work time to make it happen as of yet.
Show messages: All  1-6  7-8
