How make this into a solid??
All  1-5  6-8
10311.6
THANK YOU!!! How did you do that?
Bob
10311.7 In reply to 10311.6
Hi Bob,
First I used the script from here to highlight all "naked edges" - those are edges that are not joined between 2 surfaces:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6051.2
That shows the areas where there are holes that needed to be filled. Then I constructed surfaces to fill in the holes, using Construct > Planar and Construct > Network a couple of times in different places. After constructing a surface I used Edit > Join to glue it together with the main body, once you have filled in pieces so there are not any naked edges anymore that makes it a solid.
So it was for the complete volume and not for thickness! :)
Show messages: All  1-5  6-8
