Array with progressively increasing gap?
All
1-8
9-11
saltab
11 May 2021 (9 of 11)
10307.9
In reply to
10307.8
Ok, it seems to work now... The only issue I found is that it only works once. So if after getting the result from shiftarray I undo the command I cannot repeat shiftarray unless I do a new array. Is that normal?
S
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
11 May 2021 (10 of 11)
10307.10
In reply to
10307.9
No! Seems a bug! :)
So UNDO to the start objet + point then Array DIr Select All call the Plug SHift Array etc...
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BurrMan
11 May 2021 (11 of 11)
10307.11
In reply to
10307.9
Hey S.....
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=5595.9
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-8
9-11
