Array with progressively increasing gap?
All  1-5  6-11
10307.6
Are you sure this "Shift Array" still work on V4? I tried different times without results...
Salvatore
10307.7 In reply to 10307.6
Hi Salvatore,
I just tested it and it's working ok for me over here in v4. Are you following the instructions to include a point object with each array instance?
Yes works fine in V 4.0 ;)
Draw some Objects + a point at the same place/object for a regular result : with the Array / Dir for example...
Deselect all
call the plugin
Select all (objects + points)
Click Start - End first Step (here 2 unities) so gap result will be here 2 4 6 8
et voilĂ  :)
EDITED: 10 May 2021 by PILOU
10307.9 In reply to 10307.8
Ok, it seems to work now... The only issue I found is that it only works once. So if after getting the result from shiftarray I undo the command I cannot repeat shiftarray unless I do a new array. Is that normal?
S
10307.10 In reply to 10307.9
No! Seems a bug! :)
So UNDO to the start objet + point then Array DIr Select All call the Plug SHift Array etc...
10307.11 In reply to 10307.9
Show messages: All  1-5  6-11
