Step-import problem
All  1-2  3-4
10303.3 In reply to 10303.1
Hi Mikko, it looks like there was a problem in processing the trimming boundary. One of the things that makes STEP import pretty complex is that different CAD programs use somewhat different methods for representing trimming boundaries. Because of that when MoI imports STEP files it needs to analyze the 3D edge curves and split them where they cross the seam of a closed surface. That's a pretty complex process and sometimes it can be a difficult calculation.
In your case there there was some problem with the seam splitting and so at least one surface has a malformed trimming boundary. I'd first probably just try deleting that face and then see if it is only a tiny spot on the actual model.
If you can post the STEP file (or e-mail it to me at moi@moi3d.com) so I can repeat the problem over here I might be able to give you some better information on it.
10303.4 In reply to 10303.3
Thanks for the input Michael. I sent the step-file via email.
Show messages: All  1-2  3-4
