Setting the default number of array copies
All  1  2-5
10302.2 In reply to 10302.1
Hi Metin, the default value for ArrayDir can be set by editing the ArrayDir.htm file inside the commands sub-folder in the install.
It's on line #45:
					<td><moi:UnsignedIntegerInput id="NumItems" default="5"/></td>
Set the default="5" to instead be default="3" and it should then behave like you're asking.
10302.3 In reply to 10302.1
Hi Metin, Could you give an example of what you want to do? I would like to visualize what you mean. :)
10302.4
Thanks a lot Michael!
Psygorn, I've made a little visual explanation of my intention:
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
10302.5 In reply to 10302.4
Thanks. :)
Show messages: All  1  2-5
