ExpIodeMove along a Curve array
10301.1
Hello to all,
1. Is there someway to adjust the distance between items that are spaced out along a curve?
2. Might both the distance between each and the total quantity of such items be adjusted?
3. Might Scalelndividual be utilized such that the items remain on the curve?
Generally, various ways to manipulate items that are positioned along a curve are elicited.
May thanks,
MindSet
10301.2 In reply to 10301.1
Hi Mindset, I think the answer to all those is "no" currently. Do you have an example you can post showing your input and desired output?
One strategy could be to set up what you want along a straight line and then use Ttransform > Deform > Flow in curve to curve mode to transfer it from a straight line onto a curved path.
10301.3 In reply to 10301.2
Curves aside, if ExpIodeMove were optionally constrained by axis, likely by checkboxes, it would make a really good enhancement.
It would elevate the ExpIodeMove command comparably to how the "Set XYZ" button upgraded the Move command!
Moi Bueno
MindSet
