Does Curve 3 points show Tangent mode?
 1-14  15-34  35-54  55-62
10300.55 In reply to 10300.52
Hi, and tanx :)
But Michael already solved the problem! :)
10300.56 In reply to 10300.54
Hi Psygorn, I'm glad that method works for you!
How would you be expecting this one to work as a "built in" option?
<<< .0000000000000000000000000314
seems number of Pi! :)
10300.58 In reply to 10300.56
Hi and thank you.
I meant it would be good if I could draw a curve and then have it tangent to both the desired point of the line and the circle.
I love those tricks- mirroring the circle and then draw the Circle Tan- however, I think if there was a method with which user/s could create such curve without applying those tricks that would be awesome. :)
10300.59 In reply to 10300.57
Yes! I would like to know from where BurrMan took that number?
suspiciously resembling Pi!
10300.60 In reply to 10300.59
περιϕέρεια (peripheral)
We've been drawing circles!
10300.61 In reply to 10300.60
Well, better than walking in circles! ;-}
--Larry
10300.62 In reply to 10300.58
hi Psygorn,
It's not really good for something that is used very rarely to have a special command for it because that's how the UI gets very bloated and unwieldy over time.
So it would need to fit in to an existing command. Currently I think it might be problematic to try and fit this into the regular circle/arc tangent command because there isn't currently a way in the command to specify tangent to a curve and also through a point on the same curve.
Show messages:  1-14  15-34  35-54  55-62
