Does Curve 3 points show Tangent mode?
 1-10  11-30  31-50  51-62
10300.31 In reply to 10300.14
Could we expect to have such feature in Moi? Should I make a request for it in the wish list?
Note: Martin provided a simple trick which works! I know that. However, I still believe a built in feature would be nice!
10300.32
Hello guys, I have crossed upon new problem! You might be able to help :)
I tried to create Tangent curve to red line at Point_1 and the green circle.
( I know the center of the circle which is tangent to red line at Point_1 would fall on the Magenta line)
I was able to draw Blue curve using "Arc Tan" but it was by try and error method I have also tried to use Martin's method but in this problem because the blue curve should be tangent to red line at Point_1 I faced difficulties using Martin's method.
I'd appreciate any help :)
10300.33 In reply to 10300.31
Hi Psygorn,
I'll see about adding it into the circle and arc tangent commands.
10300.34 In reply to 10300.33
Tanx. :)
10300.35 In reply to 10300.33
So I have a problem with Martins video. Looking for some help.
I must be misinterpreting a click or a drag.
I make the line and 2 circles. Then offset the line the distance of circles.
Start the tangent circle command and select on first circle.
Second click on line ends command for me. It seems Martins video gets a second point click there, then third pick on second circle is a diameter pick for the tan snap...
What have I missed?
10300.36 In reply to 10300.35
Hi Burr, can you please post a .3dm file with your curves set up that isn't working as expected?
10300.37 In reply to 10300.36
Here's the file
10300.38 In reply to 10300.37
I must be doing something wrong here...
10300.39 In reply to 10300.37
Hi Burr, it's because everything isn't on the same plane, if you go to the Top view and get them all placed on the same plane then you should be ok.
10300.40 In reply to 10300.39
Ooooofff.
Thanks Michael..
If I have good understood the trick of Martin is brilliant of simplicity! Bravo!
LIttle variation
Same start with the Tangent circle...
I just made an Offset of the circle :)
(seems this time at any zoom there is no overpass of the arc! :)
EDITED: 5 May 2021 by PILOU
10300.42 In reply to 10300.41
Yes! There is no overpass of the arc! :)
Seems if i try to put a point on a "tangency"
point choices the vertical line and there is no real contact tangency?
Does this normal ?
it's a mega super ultra zoom :)
The green arc never touch the black vertical... and don't overpass it, (that is good :)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/arc_tangency.3dm
10300.44 In reply to 10300.43
Hi Frenchy,
I think that is just display, or even an accuracy setting, that is way beyond normal.... So MoI is giving the snap/pick as the same.
Try draw a line, then measure it... It is still beyond the decimal precision selectable in Moi.
Hand Drawn and snapped objects equal the same size.
So My Conclusion is just some abnormally unrealistic Zoom will produce odd things to look at..... :o
10300.45 In reply to 10300.44
Agree - Most likely a math precision issue or artifact of the graphics engine.
Draw a square, copy it and assign a unique color to each. Use the alignment tool to left align one square against the other.
Zoom in to the sub-atomic level. There is a gap between the lines. Good enough for me :)
10300.46 In reply to 10300.45
This is a nice read. You can skip down to the "position" bullet...
https://www.rhino3d.com/features/accuracy/
10300.47 In reply to 10300.44
Yes at extreme zoom you'll start to see visible evidence of how floating point numbers work. Basically there are little teeny tiny jumps between representable numbers.
10300.48 In reply to 10300.47
So MoI needs a sub-atomic, Nano button, so i can draw fingers on amoeba!!!
(Please read as a joke)
10300.49 In reply to 10300.32
Hello folks :)
Any Simple Solution to this problem?
10300.50 In reply to 10300.49
Hi Drillbit,
""""""Any Simple Solution to this problem?
Are you referring to this display thing we've been discussing?
If so, the answer is "dont zoom in to
.0000000000000000000000000314
And expect good results...."
We haven't really been discussing a "problem" but more of an artifact of a particular unusual use....
Show messages:  1-10  11-30  31-50  51-62
