Does Curve 3 points show Tangent mode?
 1-2  3-22  23-42  43-62
10300.23 In reply to 10300.1
10300.24 In reply to 10300.22
Pilou -
I zoomed in to the microscopic level on my model and indeed it's not tangent. Then I tried the Jfs (PAQUICINNO) method in his video (which I think is the better solution), and it also was not tangent. Of course these are visual checks.
I don't know the mathematical solution, or even if displayed curves are 100% visually accurate when zoomed in that far.
Practically speaking, the error I saw when zoomed in that far is below the resolution on my micrometer :)
But it would be nice to verify what the precise solution is.
Update - I see Michael has linked to a solution above. Who wants to test it? :)
From https://www.quora.com/How-do-you-construct-a-circle-passing-through-2-points-outside-line-L-and-tangent-to-line-L?share=1
I think this one is the easiest:
Create circle/arc 3 pts through points A, B, P.
10300.26
Here's a video I made that demonstrates a reasonable way to make the tangent.
https://vimeo.com/545453177
Martin.
10300.27 In reply to 10300.26
Nice solution Martin!
10300.28 In reply to 10300.26
hi Martin
Nice vidéo; Very Clever !
EDITED: 5 May 2021 by CHRI
Size: 76 KB, Downloaded: 56 times, Dimensions: 1418x789px
10300.29 In reply to 10300.24
Hi Ed,
I was suspicious about your solution. and yes I think PAQUICINNO's method works better maybe! ( yet it needs to be proved mathematically)
And I checked something when there is a line tangent to a circle and when you zoom in on atomic scale you see that there is a tiny gap between tangent line and the circle - which I believe it is normal to see such thing at such microscopic zooms - but there are no several crossings!
And feel free to check what I said in the attached file.
10300.30 In reply to 10300.26
Thanks Martin :)
Your trick was genius!
10300.31 In reply to 10300.14
Could we expect to have such feature in Moi? Should I make a request for it in the wish list?
Note: Martin provided a simple trick which works! I know that. However, I still believe a built in feature would be nice!
10300.32
Hello guys, I have crossed upon new problem! You might be able to help :)
I tried to create Tangent curve to red line at Point_1 and the green circle.
( I know the center of the circle which is tangent to red line at Point_1 would fall on the Magenta line)
I was able to draw Blue curve using "Arc Tan" but it was by try and error method I have also tried to use Martin's method but in this problem because the blue curve should be tangent to red line at Point_1 I faced difficulties using Martin's method.
I'd appreciate any help :)
10300.33 In reply to 10300.31
Hi Psygorn,
I'll see about adding it into the circle and arc tangent commands.
10300.34 In reply to 10300.33
Tanx. :)
10300.35 In reply to 10300.33
So I have a problem with Martins video. Looking for some help.
I must be misinterpreting a click or a drag.
I make the line and 2 circles. Then offset the line the distance of circles.
Start the tangent circle command and select on first circle.
Second click on line ends command for me. It seems Martins video gets a second point click there, then third pick on second circle is a diameter pick for the tan snap...
What have I missed?
10300.36 In reply to 10300.35
Hi Burr, can you please post a .3dm file with your curves set up that isn't working as expected?
10300.37 In reply to 10300.36
Here's the file
10300.38 In reply to 10300.37
I must be doing something wrong here...
10300.39 In reply to 10300.37
Hi Burr, it's because everything isn't on the same plane, if you go to the Top view and get them all placed on the same plane then you should be ok.
10300.40 In reply to 10300.39
Ooooofff.
Thanks Michael..
If I have good understood the trick of Martin is brilliant of simplicity! Bravo!
LIttle variation
Same start with the Tangent circle...
I just made an Offset of the circle :)
(seems this time at any zoom there is no overpass of the arc! :)
EDITED: 5 May 2021 by PILOU
10300.42 In reply to 10300.41
Yes! There is no overpass of the arc! :)
Show messages:  1-2  3-22  23-42  43-62
