"Cyber Klaus Meine Cthulhu" (Giger Style)
 1-6  7-22
10293.7 In reply to 10293.6
You have a command for cables by Max Smirnov ;)
Wire
http://moi3d.com/forum/index.php?webtag=MOI&msg=8301.20
and a modification y Marco for input any profil!
Wire2
EDITED: 5 May 2021 by PILOU
10293.8
Super-impressive work, Christian, kudos!
May I ask which renderer you've used? Maybe Octane? I'm into Octane lately, using Blender as its host.
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
10293.9 In reply to 10293.6
Tanx for the explanation :)
10293.10 In reply to 10293.7
How does that modification works? (How can I use that?)
10293.11 In reply to 10293.10
Just unzip and put these files inside the commands folder
http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=e96f49498fe8971448bbf73b80f86141&filename=Wire2.zip
Draw any "one" profil even "curvated" ( closed or not ...if "not" of course your cables will be also "open") , draw any volumes with faces
Run the plugin and follow it
so Select the "Source" Profil
Pick first Point on a face (even a point on the empty space!!! )
Pick second Point on another face (even a point on the empty space!!! )
That all! Have fun wiring! :)
Here points are on the empty space! :)
EDITED: 6 May 2021 by PILOU
10293.12
Body Kitbash Test
10293.13 In reply to 10293.11
Tanx :), I did it!
Yet, I have got a question for you. could we have control over the path of the wire?
10293.14 In reply to 10293.12
wooow!
How long it took for you to get to this level of mastery? I mean I am trying to create such models you create but it seems my progress is slow! What tips or advice you have for me to make my progress faster?
10293.15 In reply to 10293.14
I am create things in MoI3D since aroundabout 2009 or 2010, I think.
10293.16 In reply to 10293.15
Ah ok :)
You are so good at it! Amazing! :)
And tanx to Michael :)
10293.17 In reply to 10293.13
<< in Moi about wire2 : control of the path of the wire
just a little relative control : by the parameters...but the path itself is just a result of the parameters!
Make sweep if you want more...
10293.18 In reply to 10293.17
I admire your models, renders and technical creativity.
Excellent!
Mik
10293.19 In reply to 10293.17
I C. Tanx
10293.20 In reply to 10293.8
Render used by Zarkow ;)
https://www.artstation.com/artwork/Nx0AQJ
<<Modeled in Moi3D
<<Rendered in Octane for C4D
10293.21 In reply to 10293.14
<< What tips or advice
Start with small objects...
10293.22 In reply to 10293.20
"Render used by Zarkow ;)
Modeled in Moi3D
Rendered in Octane for C4D"
Thanks Pilou!
Octane, nice.
Show messages:  1-6  7-22
