Mixer
All  1-10  11-13
10290.11 In reply to 10290.10
Tony -
It all began here: (there is a lot to read :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.173
Max (the author) blog:
http://moi.maxsm.net/
The latest Scripts are here:
http://moi.maxsm.net/files/
Max's SubD Videos:
https://www.youtube.com/watch?v=RGrfb1toL9M
https://www.youtube.com/watch?v=VXazaLG0VYc
https://www.youtube.com/watch?v=8BhtWMy6A-4
https://www.youtube.com/watch?v=3LvJB98M2To
https://www.youtube.com/watch?v=CW2WVM_XYhI
I started building the faucet base by Extruding a 6-sided polygon in the vertical direction (Don't cap the ends), then added Splits. I extruded another 6-sided polygon in the horizontal direction (Don't cap the ends), and added Splits for the spout. I deleted 2 quads in the base (leaving 6 open edges), then patched in the spout using Lofts (Straight / Exact option). Next I performed Lofts to cap off the top of the base and the end of the spout. Then I Joined everything and turned on Show Points. From there it's a process of adding Splits and manipulating points (Vertices) to obtain the shapes you want (Alignment & Rotate tools work well here). Final step is to perform SubD to make everything smooth.
EDITED: 1 May 2021 by EDDYF
10290.12 In reply to 10290.11
Hi and (EDDYF)
I didn't quite understand how it works .... I'll watch the videos you attached to me.
Thanks so much
10290.13 In reply to 10290.9
Magnificent job ed
is it a drawing ?
is it a picture ?
imposssible to know
Chri
Show messages: All  1-10  11-13
