MOI5 Wish list
 1-15  16-35  36-50
10289.36 In reply to 10289.34
Here's hoping! :D
10289.37
Can we have something like this, please. A quick way to exchange the two values when using the chamfer tool.
10289.38 In reply to 10289.37
Hi 3image,
Update the MoI v4 Chamfer.htm and Chamfer.js (in the install's commands folder) with the attached versions and also put the attached Swap.png inside the install's ui folder.
That should then give you a swap button like this:
10289.39 In reply to 10289.38
Very cool! :)
10289.40 In reply to 10289.38
That is so cool, Michael, thank you very much. I've missed something like this for years and finally decided to write a proposal in the forums.
Seems very cool indeed! ;)
10289.42 In reply to 10289.25
'Quite often after creating the object from curves I want to do some operations using edges. And as I have curves in the same area I have to hide curves first. This quickly gets annoying.
In Rhino we get a little pop-up when there are multiple objects in the same place so the user can pick the desired one. That, or some setting which would allow you to define priority (for example edges over curves) would be great.'
Revit has a function where you just hit 'tab' and it cycles through the objects the mouse is hovering over. I miss it in other softwares...Very very handy, quick, and yes far less intrusive than the Rhino pop-up...
- Rich
10289.43 In reply to 10289.21
How can I setup Screenshot upon Save, in the meantime?
10289.44 In reply to 10289.43
Hi Mindset,
I've got filesystem plugins for showing .3dm thumbnails implemented for the next v5 beta, I'll try to get it wrapped up soon.
10289.45 In reply to 10289.44
WOW❗
10289.46 In reply to 10289.45
The menu bar can be customized to add plug-in functions?
10289.47 In reply to 10289.46
10289.48 In reply to 10289.47
you can click an Add button, the commands folder will be displayed. If you select a plug-in, it will be displayed on the menu
Would love to see MoI get MDI tabs….
10289.50
Please add "Edit points" and "Point objects" as children of "Points" in the Types area of the browser. I find myself wishing that I could filter window selection to just edit points.
- Peer
Show messages:  1-15  16-35  36-50
