| Hi Andy, the bright yellow color is for the selection state. When the curve is bright yellow that means the curve as a whole is selected.
 If you then click and drag on a control point, selection shifts to the control point and away from the curve as a whole resulting in what you describe.
 > Why not just keep it as bright yellow while the control points are being adjusted?
 Because the bright yellow is for showing selection, it's not tied to "control points being adjusted".
