Loft With Guidelines
 1-4  5-24  25-33
10287.25 In reply to 10287.24
Hi Andy, looks like sweep is having some difficulty with the 3D rails having tangent directions diverging from one another.
10287.26 In reply to 10287.23
Hi Andy,
> Why not have two parallel tracks?
Because there is more administrative work to keep track of more versions like this. Keeping things simple and streamlined is one of the things that helps me to operate as a single person business.
Bug fixes for v4 that were reported during the v4 beta releases are in the v4 final release.
> I assume that if someone uses V5 beta then they lose access to that when the beta is over
> and therefore lose access to the V4 bugfixes in it?
The changes made during the v5 beta process will be for the v5 release, the v4 release is done and locked down.
But yes, to keep using v5 after the beta period is over you would need to upgrade to v5 when the beta period is finished.
10287.27
OK, I now have a part I am happy with - how do I get it watertight for 3D printing?
It's composed of:
- two solids from the STEP part I imported
- the eight networks
I've tried:
- joining the networks together
- separating the solids into surfaces and then joining those surfaces with the networks (seems doing that converts the surfaces back into the two solids)
- separating the solids into surfaces, selecting only all of the surfaces and then exporting
Any ideas what the steps are? Thanks, Andy
10287.28 In reply to 10287.27
Hi Andy, you generally would use the Edit > Join command to glue surfaces together to make a solid.
However, you have some prep work to do first, there are some internal surfaces you need to delete first, for example if I hide this part:
You can see that there is a face on the inside of everything here:
There's also a similar one on the other side:
The Join command will join "naked edges" to other naked edges. A "naked edge" is an edge that belongs to only one face instead of being joined between 2 faces.
Your network surfaces have naked edges so they are ready to join. The other parts where you want to join them into do not have naked edges, they will once you delete those internal surfaces.
10287.29 In reply to 10287.27
Deleted
EDITED: 29 Apr 2021 by BARRY-H
10287.30 In reply to 10287.27
So yes you are super close to being finished there. You just need to delete the 2 faces on the inside that I showed above, then you can select everything and do Edit > Join and have a solid so it's ready to be sent for printing.
If the object type indicator here shows says it's a "surface" or "joined srf" then that means there is some opening in it that still needs to be closed off for it to be watertight. If it says solid then there aren't any naked edges so it's watertight:
10287.31
Great, thanks! Andy
10287.32
10287.33 In reply to 10287.32
Turned out great Andy!
Show messages:  1-4  5-24  25-33
