Creating a 3d solid of a non-symmetrical curved shape
All  1-5  6-16
10286.6 In reply to 10286.5
Gunter - I drew it in side view and made sure the end points touch where the red & blue lines meet. Should work fine if you have Object Snap turned on.
10286.7 In reply to 10286.6
Great, thank you Ed!
Gunter
10286.8 In reply to 10286.5
Hi Gunter,
If you show the curve points the the start point and next point should be inline and same for end points.
So if you mirror the object the join is tangent.
Hope this helps.
Barry
So a minimum of 3 different methods :)
10286.10 In reply to 10286.9
Well ... As long as we are counting Pilou :)
We have the SubD method. But not recommended for this application as the NURBs methods are more precise and easier to edit.
EDITED: 24 Apr 2021 by EDDYF
10286.11 In reply to 10286.10
The SubD method is the poetic method! :)
10286.12
Hey guys been away for a while popped in to see where MoI is at, I see Pilou is still here :)
Sometimes the MoI basics work well and maybe forgotten I'm a bit rusty with MoI so forgive the delays.
https://1drv.ms/v/s!ApWUOZf6_c8wlFBPi6NHS6pePYZf?e=DZgqV2
The Blend method is the 5 th element! :)
10286.14 In reply to 10286.1
Hi Gunter.
Here's a method.
10286.15 In reply to 10286.14
And then another way to create the pod. Possibly more sidewall control over thickness, etc...
Bravo to BurrMan!
Thinking 2 another ones! :)
by Max Smirnov http://moi3d.com/forum/index.php?webtag=MOI&msg=6514.1
An the Flow function who surelly makes something! :)
Just draw a profil target around the circles and project a surface!
EDITED: 26 Apr 2021 by PILOU
Show messages: All  1-5  6-16
