Bague - Ring
All  1-7  8-12
10279.8 In reply to 10279.7
Hi Zooen,
the attached photo shows a method of blending between the main shank and the final mount positions.
This is achieved by flowing only part of the shank and then blending to the desired mount claws.
I used only the centre line curves of the wires for the twist and flow then blended to the desired mount lines.
I then joined and rebuilt the curves before sweeping the wire circles and filleting the ends.
Hope this helps.
Barry
Nothing with the above but who knows! :)
WIres & Wires2 : in one you can choice a profil, in the other one you can choice the diameter...
for French https://moiscript.weebly.com/scripts-de-max-smirnov.html (Scroll down)
for English http://moi3d.com/forum/index.php?webtag=MOI&msg=8301.20
all create a wire between 2 points of a surface(s) or from nothing of the empty space!
Orange & violet image by Max Smirnov
Third parameter don't shown on the animation is the moving inside volume of the extremities!
10279.10 In reply to 10279.9
not used the wire script before but can be used for this method.
Barry
10279.11 In reply to 10279.10
Excellent!
here a little one with the "wire" command... ;)
EDITED: 23 Apr 2021 by PILOU
10279.12 In reply to 10279.8
Hi Barry,
Thank you, the idea is interesting
- Zooen
Show messages: All  1-7  8-12
