Bague - Ring
All  1-4  5-12
10279.5 In reply to 10279.4
Phiro >Le problème est sur l'emplacement des griffes, leur taille ou sur la courbure ?
Oui, c'est exactement cela. J'ai dû anticiper la courbure des branches (griffes) avant de faire le "Flow" donc aucune chance d'avoir une position correcte (je ne maîtrise peut-être pas). J'aurais aimé pouvoir le faire à la fin, par rapport à la pierre et/ou l'écrin avec un outil cage ou courber. Je suis confiant MoI aura certainement des outils de ce genre à l'avenir. Ou bien ils existent et je ne sais pas les utiliser.
Yes, that's exactly it. I had to anticipate the curvature of the branches (claws) before doing the "Flow" so no chance of having a correct position (I may not be in control). I wish I could do this at the end, versus the stone and / or the case with a cage or bend tool. I am confident MoI will certainly have tools like this in the future. Or they exist and I don't know how to use them.
EDITED: 20 Apr 2021 by ZOOEN
As Pilou said, the Flow function is pretty good for this.
But be carefull, this is not the same thing as a deformation cage.
Another point, to help you and tuning the right placement, you can use the "history".
With Flow + history, you can tune the deformation in real time.
Last Advise, think about the number and place of points of the source and target curves of the flow before flowing. It could help you too.
10279.7 In reply to 10279.6
Hi Phiro
Yes. It is certainly the solution for adjustments and positioning. I must fully appropriate the use of history.
Ah! I am aware of that, but I regularly forget to check the points of the curves. reflexes to acquire.
- Zooen
10279.8 In reply to 10279.7
Hi Zooen,
the attached photo shows a method of blending between the main shank and the final mount positions.
This is achieved by flowing only part of the shank and then blending to the desired mount claws.
I used only the centre line curves of the wires for the twist and flow then blended to the desired mount lines.
I then joined and rebuilt the curves before sweeping the wire circles and filleting the ends.
Hope this helps.
Barry
Nothing with the above but who knows! :)
WIres & Wires2 : in one you can choice a profil, in the other one you can choice the diameter...
for French https://moiscript.weebly.com/scripts-de-max-smirnov.html (Scroll down)
for English http://moi3d.com/forum/index.php?webtag=MOI&msg=8301.20
all create a wire between 2 points of a surface(s) or from nothing of the empty space!
Orange & violet image by Max Smirnov
Third parameter don't shown on the animation is the moving inside volume of the extremities!
10279.10 In reply to 10279.9
not used the wire script before but can be used for this method.
Barry
10279.11 In reply to 10279.10
Excellent!
here a little one with the "wire" command... ;)
EDITED: 23 Apr 2021 by PILOU
10279.12 In reply to 10279.8
Hi Barry,
Thank you, the idea is interesting
- Zooen
Show messages: All  1-4  5-12
