Multitouch pan/zoom peculiarity
All  1-6  7-9
10277.7 In reply to 10277.6
Hi Larry, over here it seems like it may have something to do with the machine waking up from sleep. Also on the second time that I triggered it somehow it went away without restarting MoI after the machine went through another sleep/wake cycle.
Right now i suspect some kind of OS bug in gestures when waking from sleep but I'll keep poking at it.
10277.8 In reply to 10277.6
Oh yeah by the way if you do a 2 finger double tap ("smart zoom" gesture) that does a view reset.
10277.9 In reply to 10277.8
Well "it" happened again, but I still don't know what caused it. No sleep/wake involved, just seemingly normal work leading up to it.
One interesting aspect is that I had two instances of MoI running. The first (main) instance had my model open while the second was to open a .DXF file of parts that had just been nested (using deepnest.io for what that's worth). I had just copied the nested parts from the DXF instance and pasted into my model when I noticed the main instance was now locked on zoom for the 2-finger gesture. I finished my work and closed the main instance. This morning I noted that the DXF instance was still open and was interested to note that it too had the zoom behavior. Now, the MacBook Pro did sleep overnight and I do not know if it exhibited the zoom behavior before the sleep.
I think the root cause is covid...everybody using zoom & MoI doesn't want to feel left out... ;-}
--Larry
Show messages: All  1-6  7-9
