Unit system
All  1-2  3-7
10276.3 In reply to 10276.2
Hi Michael, thanks for taking the time. That export setting in options is good to know. I was able to resolve this issue. I believe I did something along the lines of copying the solids. opening a fresh file. Changing unit system to inches (as that is what I initially started with file revisions ago). Pasted solids in. made sure "scale on unit system change" was checked. Changed unit system to millimeters. At least that's how I think I did that.
10276.4
HI,
Concerning the unit, I'm not sure I understand what the "unit options" button is.
Why is there a second set of unit system ?
Marc
10276.5 In reply to 10276.4
Hi Marc,
The one on the main dialog sets the unit system for the current open model.
The one on the "Unit options" dialog that says "Default unit system" sets the default that is used when you initially start up MoI (if no template file is being used).
Changing the "Default unit system" does not change the current model units, it only changes what is used on start up.
10276.6
Got It, thanks for the clarification.
Maybe renaming the button "startup unit options" would be more clear?
Marc
10276.7 In reply to 10276.6
Hi Marc,
Well there are 3 options on the dialog that it pops up, and only one of the 3 involves startup.
Show messages: All  1-2  3-7
