nodeeditor scaling a curve in one dimension
10275.1
Dear all,
i'm trying to get used to the elements (and the logic) of the nodeeditor and many things really works fine. But I guess I still have deficits in understanding basic things.
I like to scale a curve (object) in one axis as you normally can do it in MoI with the "Scale"-button or by directly modifying the i.e. Y-dimension number in the data editor of the curve.
I found an example how to scale an object with the "ScalePts"-node in combination with "CloneToPts" what works fine, but this is scaling the object in all 3 dimensions (and I just like to have it scaled in one dimension).
Do you know how this can be realized?
Thanks in advance for your hints/solutions!!!
Greetings,
Joerg
EDITED: 11 Apr 2021 by SUNSPEED
10275.2 In reply to 10275.1
Take a look here! ;)
https://moiscript.weebly.com/objects2.html#scaleuvw
If you take only one(s) U, V W you will have that you want & more!
10275.3
Example
Size: 160.4 KB, Downloaded: 49 times, Dimensions: 1478x774px
10275.4 In reply to 10275.2
Oh no, that's so easy! I am a real beginner and would have better had first a look to the U, V, W theory to understand this.
But Pilou and WN, thanks a lot for your help and time!!
Joerg
10275.5 In reply to 10275.4
U,V,W is exactly the same than X,Y,Z ! :) (Normaly used for Texture 3D coordinates in 3D Polys progs)
EDITED: 12 Apr 2021 by PILOU
