Connect two circles with a tangent
10273.1
If I have two circles, is there a way to construct a line that is tangent to both circles?
10273.2 In reply to 10273.1
Hi Andre,
Yes, make sure you have Object Snap enabled in the bottom toolbar, and that you have not inadvertently turned off the "Tan/tan" snap type.
You'll then be able to get a line like that using the Line command like this:
10273.3
Oh wow, I didn't notice the starting point snaps as well. That's awesome.
10273.4 In reply to 10273.3
PS Your circles must be on the same plane !!! ;)
10273.5 In reply to 10273.3
Hi Andre, yes there are 2 snaps - tan/tan and perp/perp - that modify both the start point as well as the end point when it engages.
10273.6
Worked for me for the first two lines but then wouldn't work for the next one. V4. Circles are on the same plane. Andy
10273.7 In reply to 10273.6
Hi Andy, looks like there's some kind of bug in handling the tan/tan snap when it's also on a surface.
Does it work ok for you if you temporarily hide the solid?
10273.8
Hi all.
If the body is hidden, it works normally.
Size: 156.6 KB, Downloaded: 24 times, Dimensions: 1920x1078px
Size: 161.6 KB, Downloaded: 24 times, Dimensions: 1920x1078px
