Mesh Import
All  1-3  4-8
10272.4
Importing just the vertices should be straightforward and would help enormously to reconstruct imported objects by snapping new geometry to the imported vertices, so I'm still hoping Michael changes his mind at some point. :)
10272.5 In reply to 10272.4
Hi Andre, there is a converter app here which will open an .obj file and convert it the polygon edges into line segments in a 3DM file which you can then load into MoI:
http://moi3d.com/download/Obj23dmWireframe.zip
10272.6
Whoa, that was here all along? At least for me that actually solves most of my STL import needs.
10272.7 In reply to 10272.6
Hi Andre,
Pretty close, it's been there on https://moi3d.com/resources for 9 years now.
You have also _ImportObj by Max Smirnov for OBJ format...
http://moi.maxsm.net/files/scripts/ImportObj.v.1.5.2015.09.10.zip
Better if your obj is "Ngons" (quadrangles is the best)
150 000 polys is reasonnable
Press Tab and write _importObj
When you have import it : Select by Browser's button "Edges" copy move them ... you have segments as support new drawing...
You can of course Sudvide after it if necessary...
The complete thread ;) http://moi3d.com/forum/messages.php?webtag=MOI&msg=6674.1
http://moi.maxsm.net/files/scripts/Subdiv_beta9.zip
Press Tab and write Subdiv_beta9 (or make a ShortCut)
You have an other native method of subdivision : SubD / Create from file (OBJ format)
EDITED: 11 Apr 2021 by PILOU
Show messages: All  1-3  4-8
