Organising Scripts
All  1  2-6
10269.2 In reply to 10269.1
Hi Barry, I don't think there is a provision for that in Max's UI but here is one that you could build up from:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8979.1
10269.3 In reply to 10269.2
thanks will take a look.
Is it possible to organise the list by adding a prefix to the scripts thus grouping them in proposed sections ?
Barry
10269.4 In reply to 10269.3
Hi Barry,
I don't think it is set up to work like that currently.
10269.5 In reply to 10269.4
I added the ! prefix to a script in appdata and it moved it to the start of the list and if I remember correctly
the _ prefix was used to put scripts at the start of the list thus short cutting the alphabetical sorting.
So is it possible to add a symbol or letter to the script title html & JS file that will then sort the scripts.
If not Dino's method requires adding the ! prefix to the script title how is this done when the script is in the appdata location ?
Barry
10269.6 In reply to 10269.5
Hi Barry,
I don't think that adding a symbol or letter will do anything automatically, you would need to modify the code for the scripts menu for it to pay attention to that stuff.
There are some instructions in the original post here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5993.1
I think the ! mark is intended to be added into the shortcut key.
Show messages: All  1  2-6
