How to offset faces of a solid inward or outward
 1-19  20-29
I believe i understand that you have made!
I project curves Offseted
Trim the Volume
Kill curves
Select external faces of the "moved piece"
Inset 0 - Use separate height as you want (little measure of course)
Move in place
Boolean Union
It's a solid! :)
(it's a pity that we can't select directly only "Front faces" of the gap's face or i miss something :)
In fact we are obliged to move the piece even separated there is creation of vertical pieces at the angles!
That is not the case in the empty space! :) See animation above!
EDITED: 3 Apr 2021 by PILOU
10267.21 In reply to 10267.20
https://www.youtube.com/watch?v=CR0nAcfJ2No
@PILOU- Here is a video of what I did.
@ parel : cool pedagogic video !
Very mysterious : today that works as excepted! So more easy !
And better (very curious again): select faces "trimed" Inset don't works
but if you call Details & select "4 faces" then call Inset that works fine!
So a groove is made with only one click after the trim with the Inset "0"! (curves killed)
No need to select one by one as the image!
PS Works only for ortogonal path ! Better than nothing! :)
EDITED: 5 Apr 2021 by PILOU
About the Chipp 's video above...
You can make the same more easily with enable the Grooved option! ;)
You can also replace the Inset "0" by a value and at the end make a boolean Union!
Inset Multiple :)
10267.25 In reply to 10267.24
OK-Solved what I originally came for. Posting a video of a decently repeatable workflow.
https://www.youtube.com/watch?v=pLiOV2rPcYo
10267.26 In reply to 10267.25
Thanks for this video
-Zooen
10267.27 In reply to 10267.25
Excellent!
by parel
EDITED: 6 Apr 2021 by PILOU
Message 10267.28 deleted 6 Apr 2021 by PAREL
10267.29 In reply to 10267.27
Thanks PILOU!
Show messages:  1-19  20-29
