Can you do this
All  1-5  6-10
10266.6 In reply to 10266.5
> Trick of Michael gives more precise result than me but will be more long if they are many segments! :)
It doesn't really take long to do many segments, you can do around one corner every second with the above method. So with a 100 segments should be done in less than 2 minutes.
10266.7 In reply to 10266.6
Sure only the result counts in reasonable time! :)
10266.8
Hi michael
Really splendid, as always your solutions are magnificent and very detailed. And also I have learned something that I did not know, that you can select parts of the same type from Details
Thank you so much
10266.9 In reply to 10266.2
Thanks Pilou.
I'm not sure I have understood your solution, the problem may be the GG translation, but Michael's solution is perfect for me.
I don't know if it would be helpful if someone made a script for this?
10266.10 In reply to 10266.9
Yes an exotic solution! :)
Show messages: All  1-5  6-10
