Can you do this
All  1  2-10
10266.2 In reply to 10266.1
I don't believe there an automatic "UnFillet" (except CTRL Z :)
but you can maybe make something like this
Line Web : http://moi3d.com/forum/index.php?webtag=MOI&msg=3666.1
Copy vertically your curve
Call LineWeb
Connect by line (any number you want) here 10
Select the vertical lines created - only little problem you must select these vertical lines in order horlogic or unhorlogic
(no problem if your first curve was drawn in order so a rectangular selection from Right to Left will work)
Connect lines "Closed" enable (3 as number) :
You have your curves with angles points! Maybe with a little deviation but... ;)
EDITED: 3 Apr 2021 by PILOU
10266.3 In reply to 10266.1
Hi Booleano, I don't know of a script for doing that. Probably the easiest way is to use Edit > Separate on the curve to break it apart. Then select and delete all arc curves (select all and then use Details... to select arcs). Then select a pair of lines at a time and run Edit > Extend. Right click to do "Mutual extend". Select another pair and right click to repeat the extend command, etc...
That goes pretty quickly, here's what it looks like:
10266.4 In reply to 10266.1
EDITED: 3 Apr 2021 by CHRI
Trick of Michael gives more precise result than me but will be more long if they are many segments! :)
10266.6 In reply to 10266.5
It doesn't really take long to do many segments, you can do around one corner every second with the above method. So with a 100 segments should be done in less than 2 minutes.
10266.7 In reply to 10266.6
Sure only the result counts in reasonable time! :)
10266.8
Hi michael
Really splendid, as always your solutions are magnificent and very detailed. And also I have learned something that I did not know, that you can select parts of the same type from Details
Thank you so much
10266.9 In reply to 10266.2
Thanks Pilou.
I'm not sure I have understood your solution, the problem may be the GG translation, but Michael's solution is perfect for me.
I don't know if it would be helpful if someone made a script for this?
10266.10 In reply to 10266.9
Yes an exotic solution! :)
Show messages: All  1  2-10
