La pince à linge - The clothespin Closed
 1-10  11-30  31-50
10265.31 In reply to 10265.30
Hi Micharl.
It's perfect, I didn't remember that Blend could also be used in curves.
Is there a script to be able to move a line tangent to the perimeter of a circle, ellipse or curve?
In the case of this spring, it is very difficult to place the end 'A' tangent to Helix at point 'B' or at another point.
Move the lines from points 1-2-3-4 around the circle keeping the tangent lines, as seen in the attached image.
I hope the translation is understood
EDITED: 22 Sep 2024 by BOOLEANO
  More Options
10265.32 In reply to 10265.31
Hi Booleano, I'm not sure that i understand your script request. Why do you need to move the lines around, why not just draw a new tangent line at the spot that you want it?
You can move one tangent line around keeping it tangent using the Transform > Orient command, when snapped onto a curve the orientation picker aligns to the curve tangent.
  More Options
10265.33 In reply to 10265.32
Hi Michael.
With Orient command, at least I, I can't do what I want.
As it is difficult to explain, I am attaching a video that shows what I need to do.
All these questions that I ask are related to the exact mathematical method to make the clothespin spring, which seems to be very simple but has its complications, and it is essential to know exactly the tangent point of Helix with respect to the 2 points of the dock.
Because in order to have this spring manufactured, which for me only serves as an example, it must be completely delimited with respect to wood.
Cheers.
  More Options
10265.34 In reply to 10265.33
Hi Booleano.
This can be done like this.
Size: 152 KB, Downloaded: 35 times, Dimensions: 1461x940px
  More Options
10265.35 In reply to 10265.33
You got ahead of me. I just did this, which is exactly like yours.
The calculation is not complicated, but Moi would make it much easier.
I really don't know why it always shows the tangent point, except when there is a reference point.
  More Options
So the manufacturing method i see that deals with th physics of the "wood binding" at the springs connection points is missed on these models.
The arm that extends to the connection point is not parallel with the wood pin. The helix ends "at the edge of the wood" and the arm then extends "out" in the tangent of the helix. Then, the connection point is a bend "past 90" to align with the wood slot.
This eliminates the physics of the bind. It is also a simplified manufacturing process easily automated. No "complex" bends.
  More Options
10265.37 In reply to 10265.33
Hi Booleano,
Can you please also post the . 3dm model file with the objects that you show in the video?
I am not able to repeat the problem you show over here, it probably has something to do with the particular arrangement of your geometry like your reference point is not in the same plane as the circle you show.
  More Options
10265.38 In reply to 10265.34
Hi Michael.
I apologize for my question about Tangents and the "Tangent" video that I uploaded.
I was wrong, MOI's tangent detection works perfect, it has the best snap I've seen.
I am attaching a video where my mistake is clearly seen.
Sorry Michael for wasting your time addressing this mistake of mine.
  More Options
10265.39 In reply to 10265.38
And I did not see the error because I only saw the Front view, I would have activated the 4 views I would have seen my error
  More Options
10265.40 In reply to 10265.38
Hi Booleano, no problem I'm glad you found what it was.
  More Options
Message 10265.41 deleted 13 Apr 2021 by MICHAEL GIBSON
Message 10265.42 deleted 13 Apr 2021 by MICHAEL GIBSON
Message 10265.43 deleted 13 Apr 2021 by MICHAEL GIBSON
Message 10265.44 deleted 13 Apr 2021 by MICHAEL GIBSON
Message 10265.45 deleted 22 Sep 2024 by BOOLEANO
Message 10265.46 deleted 13 Apr 2021 by MICHAEL GIBSON
Message 10265.47 deleted 22 Sep 2024 by BOOLEANO
Message 10265.48 deleted 13 Apr 2021 by MICHAEL GIBSON
Message 10265.49 deleted 13 Apr 2021 by MICHAEL GIBSON
Message 10265.50 deleted 13 Apr 2021 by MICHAEL GIBSON
Show messages:  1-10  11-30  31-50
