Loop in complex objects
All  1-5  6-11
@Michael
Thanks a lot, Many time saved with this script... I knew it, but confirmed, you are a genious
It's very usefull to work with other soft or online services, like http://hypatiastudio.com/celticknots/ or to rework on exports.
@Pilou
I tested the Rocket3D loop, but Rocket3d is very cool but faces oriented, so i don't find how to export curves.
A before / After screenshot...
10262.7 In reply to 10262.6
<< Export curve
I believe you must export object then extract curves in Moi! ;)
It's the limitation of the OBJ format
but you have the export DXF ! ;)
Seems not working inside Moi :(
So I use the free astonished PCONPlanner https://pcon-planner.com
Import inside the DXF from Rocket 3F then export inside Moi DXF that works! :)
EDITED: 1 Apr 2021 by PILOU
Cool scripts !
@ Phiro
You don't want a selection of a loop edges one out of two ? Or i dreamed again ? :)
PS You have also Construct / Curve / Silhou who can give some interesting results! ;)
(just very few edges/points to erase /Add for have a complete loop)
with your file
@Phiro
Very cool prog the Hypatia onLine ! :)
Save as stl : Mesh mixer --> OBJ
Import in Moi by Native SUBD / Create from File or _importOBJ by Max SMirnov
EDITED: 2 Apr 2021 by PILOU
10262.11
- Tudor -
Show messages: All  1-5  6-11
