Spiral flow issue
All
1-7
8-11
Michael Gibson
29 Mar 2021 (8 of 11)
10257.8
In reply to
10257.4
Hi iolofato, so yes the concave shaping that you're seeing is due to "ruling line twisting" like I was showing above (
http://moi3d.com/forum/index.php?webtag=MOI&msg=10257.3
It's a type of shaping effect you can get on a ruled surface (a surface made up of straight lines connecting between 2 curves) if the ruling lines are not restricted.
If you turn on your surface control points you can see yours is similar:
- MIchael
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
30 Mar 2021 (9 of 11)
10257.9
My Moi French Site
My MagicaVoxel Gallery
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
iolofato
30 Mar 2021 (10 of 11)
10257.10
Thanks a lot to all of you, I'm sure your remarks will be really helpful ;-)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
30 Mar 2021 (11 of 11)
10257.11
For build a same line distance "Flat" to Flow
you can Array Curve a Point along a curve (here an helix)
and cut the curve at the wished distance...
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-7
8-11
