Batch create SubD from File
All  1  2-5
10255.2 In reply to 10255.1
Hi Stan, so for opening a STEP file you were probably using moi.geometryDatabase.open() ?
For opening a sub-d file same as the SubD > Create > From file on the side pane, use this:
moi.geometryDatabase.fileImportSubD();
10255.3 In reply to 10255.2
this sounds very cool! For STEP I use the following code (plus the code which retrieves files from the folder and calls Convert function) :
function Convert( FileName )
var gd = moi.geometryDatabase;
gd.open( FileName, true );
var xFileName = FileName.substr( 0, FileName.lastIndexOf('.') ) + '.3dm';
gd.saveAs( xFileName );
gd.fileNew( true );
So is that like instead of
I would use just
gd.fileImportSubD( FileName, true );
Thanks thousand times!
Stan
10255.4 In reply to 10255.3
Hi Stan,
> I would use just
That will probably work but it's actually expecting just the filename, so just put:
gd.fileImportSubD( FileName );
The additional parameter on open() is for not showing the "save changes" dialog.
10255.5 In reply to 10255.4
I got it working with True param as well, but I will modify it so it gets just file name. This will save me tons of time, thank you very much once again. Great support!
Stan
Show messages: All  1  2-5
