3d view fails
All  1-2  3-6
10252.3 In reply to 10252.2
It just hangs 'Processing Objects 0%'
10252.4 In reply to 10252.1
Hi wheable, it's because there are a couple of objects located a vast distance (about 58 million units) away:
To fix this, after loading your .3dm file, go to the Top view and push the "reset" button on the toolbar at the bottom of the viewport. You should then be zoomed to fit all objects and you can do a window select around the little spec on the left (indicated above) and delete it. After that do another view reset for all viewports by right-clicking that reset button and you should be able to work normally.
10252.5 In reply to 10252.4
I must clean my monitor. I thought that dot was where I'd sneezed on the screen :-)
Have you just got super eyesight or is there some other clue I should have seen ?
Thanks, worked perfectly
10252.6 In reply to 10252.5
Hi wheable,
Just average eyesight! :) It's when I did a view reset in the Top view that I noticed it. It's easier to see this kind of thing in a parallel projection view than in the 3D perspective view.
Show messages: All  1-2  3-6
