Revisit Fillets later on in the design
All  1-2  3-4
Or use the Elephant nodal system but it's another story! :)
For have parametric fillets...
10247.4 In reply to 10247.1
Hi David, the easiest way to do this in MoI is to save off a version of the file before you put fillets on so you can load that version back in later on and put in new fillets if you need to.
Moi does not currently have a parametric history stack that automatically keeps the unfilleted versions for you. There are other CAD programs that work like that for example SolidWorks, Solid Edge, OnShape, Alibre, ViaCAD, TurboCAD, Creo, and others.
If that type of editing is important for your work probably one of those mechanical CAD systems would work better for you than MoI.
Show messages: All  1-2  3-4
