Seams
All  1-6  7-11
You can try this script by Max Smirnov!
http://moi3d.com/forum/index.php?webtag=MOI&msg=7912.4
in this image following curves are managed before the extrusion...
In this one curves are managed directly...
10245.8 In reply to 10245.6
Micheal, thanks for your response. Like how there are multiple solutions here. :)
10245.9 In reply to 10245.7
Interesting PILOU. I have not gotten into using scripts quite yet but will try this out soon. Only gotten as far as setting custom hotkeys :)
10245.10 In reply to 10245.9
Precision...
code: (only one line)
var fs=moi.filesystem, fl=fs.getTempDir()+'tmp.stp', gd = moi.geometryDatabase; gd.fileExport(fl); gd.removeObjects(gd.getSelectedObjects()); gd.fileImport(fl); fs.deleteFile(fl);
Copy the Max's code in a .js file, and save it the "scripts" directory. (with any name you want without space )
Also the "commands" folder is ok.
To use it, simply select the curves you want to elaborate and run the command.
Load the file and put it in the scripts folder of Me (if this folder does not exist, create it)
Make a shortcut, or press TAB and write the name of the script
Select curves and call the plugin.
10245.11 In reply to 10245.10
Thanks PILOU, looks pretty straightforward.
Show messages: All  1-6  7-11
